Spark Plug Help
Started by ODZKing, June 18, 2017, 03:31:21 PM
ODZKing
Back when we did the 73 engine, in checking on plugs for the 400 4bbl, I came up with the original # of J11Y. I crossed it (then) to RJ14YC.  I am about to get a set and to my surprise, what is recommended RJ12YC which is the same plugs as my 67 - 383 4bbl.
http://www.sparkplug-crossreference.com/convert/CHAMP_PN/J11Y
So researching as I do, I realized the RJ14 is a bit longer. Not being a genius when it comes to this I have to question ... what is the difference between the two lengths and have I been using the WRONG plugs in my 73 400 4bbl all this time????  :shruggy:
Just run an NGK "XR5" plug and gap it at .035.....your motor will luv it !  :yesnod:
ODZKing
So if I go with NGK's, 400 = XR5.
How about 383 4 bbl also, which NGK for that engine?
In looking at Rock Auto, they recommend XR4's for the 383.
Quote from: ODZKing on June 19, 2017, 09:36:45 AM
Depends on the cam, compression and heads. Odds are you will end up with the xr5
ODZKing
Quote from: c00nhunterjoe on June 19, 2017, 06:11:28 PM
All stock with A LOT of miles on the old girl.  ::)
The XR5's are a great all around plug for iron head builds that run between 8.5-10.0 compression. More compression requires a colder plug while less compression needs a warmer plug.
ODZ ; I'd run the XR5's in both of those cars
ODZKing
Thanks folks. I ordered 16 NGKs from Rock Auto.  Great price I thought, $1.39 each and same shipping 8 or 16 so I ordered 2 sets. Came to $28 to me. Cheaper that could get them locally.  :2thumbs:
ACUDANUT
Quote from: firefighter3931 on June 19, 2017, 07:07:45 AM
Great Spark plug.  :cheers:
Too bad it's made in Japan. :brickwall:
69wannabe
You will be happy with the NGK's!! Like Ron said the XR5's are all around good plugs for any cast iron big block with less than 10 to 1 compression. I ran the #6 heat range NGK's in my 493 before I swapped to the stealth heads and they ran great. I am running the longer reach #6 NGK's in the stealth heads and they seem to be the perfect selection. Ron recommended the NGK's to me when I went to the firecore dizzy and wire set and they worked out great. I was always a champion guy until I tried the NGK's.......
