1973 Rallye canopy top
Started by Raindem, June 29, 2017, 12:47:25 PM
Raindem
Question for the vinyl top guys.  My car is equipped with a canopy top.  But the top and attached trim was missing when I got the car.  There is a row of body rivets across the roof, presumably to attach the rear trim piece.  At the very edge of the roof, about an inch off-center from the line of rivets, is a small dimple.  In the photo it is circled.  When I grinded off the primer and rust, it looked like a hole that someone tried to weld shut.  There is another one in the same location on the other side.
Does another rivet go here?  Or is it a screw hole?
On a more general note, how do the guys with canopy tops feel about them?  I could go either way.  But if I'm going to delete it now would be the time.
Curt
randy73
I cannot see your pic, but my 73 has the same holes and from my service manual it looks like a screw goes in there, but the manual does not have a pic of the screw.
Raindem
I'm a bit confused now.  Does the trim piece (and therefore the vinyl) curve back near the ends?  The pictures I found seem to show it going straight across, side to side.
Here's the direct link for the photo.
https://postimg.org/image/7oru2royv/
71.R/T.440-4bbl...
yes the chrome that goes across the top curves back to the side rear window on both sides. there is a stud on the chrome trim that goes through the roof & a nut on the in side of the roof.
Raindem
Ah yes, that's makes sense.  The car is currently all stripped down so I looked on the inside and sure enough, there is the stud with the nut still on it. Just took a little wiggling and it popped out of the hole.  I guess whoever took the trim off used a crowbar or something.
Raindem
Follow up question... who makes the camopy top and trim for my application?  I visited all the vendors I have links for and I couldn't find anyone that offered the top or the trim.
Curt
1973rallye
Legendary sells the tops. As for the trim, try contacting Bryan. "Vegas Charger" on this site first, otherwise it's eBay or Carlisle swap meet.
1973 Rallye 440 4 speed
2016 Challenger r/t Shaker
Raindem
I've seen canopy tops listed for a 71-74 RT, and for a 73-74 SE.  But not a Rallye.
1973rallye
Ebay motors.com and search 73 charger canopy vinyl top.
It will likely be the first item listed and supplied by Legendary. If I knew how to link it on here I would have for you. Ray
Raindem
Thanks for the reply.
Yes, I saw the ebay ad you are referring to.  It lists it as fitting a 71-74.  Is that correct?  The quarter window changed shape in 73 so I'm wondering how the same canopy top could fit both models.
73rallye
When you order, just let them know what year you need it for and legendary will send a top with the correct amount of material needed for your car. I had ordered mine from Dantes. Straight up guy and if it's not right he will make sure you get the correct top for your car.
I spotted some trim as well when I was scanning eBay for your top. The ad was pricey. 325 if memory serves me. Sadly supply and demand dictate what we pay for the things we need.
1973rallye
It's apparent I have two usernames lol. I had forgotten that I signed up years ago under 73rallye. (In case you were wondering)
Raindem
I found the trim in another ebay ad for $157 shipped.  Strangely, this ad didn't show up when I was searching ebay itself.  But when I was on another parts vendor site it linked to it.  And none of these ads show up when I surf ebay using my '73 charger saved data.  I have to do a free text search as you suggested.  So I'm wondering what is the point of having saved car data on ebay if you only see 25% of the ads.
Raindem
One more question regarding the canopy top setup.  How are the sides finished off?  Is that with the drip rail molding that I keep reading about?
Sides hides down the drip rail mold
Raindem
So the top is folded into the rain gutter?
Raindem
OK, thanks.  My car was missing a lot of the trim when I got it so just trying to sort things out.
1973rallye
Sorry I didn't get back to you. I was up at 5 and off to work. After which I packed up and headed to the lake on holiday.
Nacho is correct which shouldn't come as a surprise! :2thumbs:
randy73
Quote from: Raindem on July 09, 2017, 09:26:17 PM
I decided not to put my top back on and I have almost all the trims ( I broke 1 piece removing the top), so let me know I can maybe hook you up.
Raindem
Quote from: randy73 on July 10, 2017, 10:38:55 AM
Thanks Randy.  I've scrounged a few pieces so far.  The only ones I think I'm missing are the drip rail trim.  But since non-vinyl cars use the same pieces you probably re-used them.
1973rallye
I may still have a pair in my leftover parts. They won't be show pieces. I won't get home until Sunday. If I still have them and you haven't found any by then, you pay the shipping and they are yours. Of course before you decide I will send some pics. Ray
Raindem
That's a very generous offer.  I'll wait until you get home so you can find out if you still have them.
Curt
We got a dicussion not too long ago about vnyl top drip rail molds ARE NOT the same than non vinyl ( or halo which are the same )
Quote from: 1973rallye on July 09, 2017, 10:12:24 PM
LOL... not allways
