OK, what’s the trick
Started by RECHRGD, March 10, 2018, 06:17:27 PM
RECHRGD
To get the damn glove box door from popping open on a rough road?  The latch and everything appears to be operating correctly on my '68.  I've tried moving the catch to different positions and some washers under the latch and nothing seems to fix it.
13.53 @ 105.32
garner7555
69 Charger 440 resto-mod
cdr
If I remember correct, there are two different kids of catches for the latch, one is like a solid wire, the other is like a spring loaded crossbar, I have the solid wire type & my glove box has never popped open .
RECHRGD
Quote from: cdr on March 10, 2018, 09:01:02 PM
Hmmmm, mine is the spring loaded bar.  Can the solid wire unit be purchased?
13.53 @ 105.32
cdr
Quote from: RECHRGD on March 10, 2018, 09:23:15 PM
a used one I am sure, after some research, I would clean & lubricate the button latch real well & see if that helps 1st.
Charger-Bodie
Take the spring loaded striker off, push a plastic clip into the spring holes so it isn't spring loaded anymore and viola no more popping open.
ACUDANUT
Quote from: ACUDANUT on March 11, 2018, 08:44:01 AM
Try duct tape.  ;D
nah!, that looks ugly... better double sided tape on inner face of lid ?  :scratchchin:
RECHRGD
Quote from: Charger-Bodie on March 10, 2018, 10:41:26 PM
Thank you, thank you, thank you!!  I've been putting up with that thing for 20 years.  I just beat the heck out of the dash and the door didn't budge.......,
13.53 @ 105.32
Bad B-rad
That must be why the Duke boys welded the glove box door shut.
