Ignition Wiring
Started by krops cars, August 07, 2018, 07:48:39 AM
krops cars
On my 70 Charger I cut out all of the wires for alternator and resistor on my new harness. I could not find information on how the starting system works on the mopar. I tried the manual also. I have no power to the ignition  coil during cranking. I was going to add a diode to the from the yellow wire on the solenoid to the blue. Or is there a wire that powers up during cranking?
Brown wire is the one what feeds the coil while cranking ( Start position )... blue on Run position
Why did you cut the resistor?
krops cars
Went with fire core ignition coil and distributor. Also went with one wire alternator. Didn't want all the extra wires going no where.
krops cars
Also thank You for the information.
When using some aftermarket ignition systems, simply connect the brown (IGN2) and blue (IGN1) wire together for power in both Start and Run.
krops cars
I'm a learnen. Thanks Appreciated.
NHCharger
Is this the Firecore RTR distributor?
I'm running them on both my big block Chargers.
If so I can walk you thru what you need to do. The first distributor I bought from firecore had pretty good instructions. If you bought this thru Summit their directions suck. I would have never figured out how to run the wiring if I hadn't bought my first one from Firecore direct.
72 Charger- Base Model
68 Charger-R/T Clone
69 Charger Daytona clone- current moneypit
79 Lil Red Express - future moneypit
88 Ramcharger 4x4-moneypit in waiting
2014 RAM 2500HD Diesel
krops cars
Car is running just no spark during cranking. The guy at Fire Core I bought the distributor from was awesome. I was suppose to get my distributor that day. Did not show up. Figured I would call the guy next day. He called me at 7:00 that night. He apologized that he did not get it out and assured me that it would be going the next day. He also Thanked me for purchasing Fire Core. You know how many MSD ignitions I have put in. Not ever a Thanks. That made me feel good about the purchase. It is like they care about your project and their product.
krops cars
Brown wire was the ticket. Thanks
