RPM OER gauge
Started by q8charger, December 20, 2018, 10:57:21 AM
q8charger
Hello,
I bought Rallye Dash Tic Toc Tach Clock includes RPM OER gauge for my 1969 charger  . Any one have the diagrams please. How i can install.
AKcharger
Watching for answer as well. It didn't have instructions?
q8charger
 :shruggy: Nothing inside the Box
q8charger
it should be, one to batt feed for the clock, one from ign1 or acc to the tach, and the wire running to coil for the tach signal through the firewall... ground is chassis
Try this.
white
Will the tach work with electronic ignition with the HEI pickup distributor?
Bronzedodge
That's a good question.  The factory HEI has a tach terminal on one side of the cap.  You could just attach to the coil as normal and see if it works.
Mopar forever!
I believe the new repop tachs will work with electronic ignition but not always so with the originals.
