275 vs 295 Height
Started by JMF, March 19, 2019, 06:59:11 AM
JMF
Am I right in thinking 295/50/15's on the rear will make the car sit lower than 275/60/15's ? How many inches ?
I really want the old school look with the back almost jacked up a little so if the 295's make it sit lower then maybe I'm best with 275's ?
How come they don't do the 295's with a 60 as opposed to just the 50 ?
Also will a 295 fit on a 15 x 8 wheel or is it best to go with 15 x 10
green69rt
295x50x15 is about 26.6" diameter.  275x60x15 is 28" so the 295 will set about 3/4" lower.
The 295 tire is 295/25.4 = 11.6" wide across the tread,  I would bet the tire manufacturer would recommend nothing smaller than 9" wheel or even 9.5".
Maybe just go to a smaller front tire to get the rake you want.  Or diddle the suspension.  In any case, you will probably need an alignment when you're done.
JMF
Great thanks, i'm not talking about ridiculously jacked up, I just mean I like the rear to sit a bit higher for an old school drag racing kind of look.
50% of 295 width x 2 / 25.4 plus 15"
60% of 275 width x 2 / 25.4 plus 15"
25.4 is mm to inches conversion
cdr
green69rt
Quote from: cdr on March 19, 2019, 07:37:11 PM
325-50-15  28" tall
Charlie, what width wheels do you have on the rear?
68ChargerJMP
325-50-15  28" tall
Did you narrow your rear bumper, it looks tucked more than normal, or is it just the angle of the pic? Also, I only see one bumper bolt per side...What going on back there? Thanks.
68ChargerJMP
Whoops, I thought I was copying your pic CDR, not your tire size quote. My bad.
cdr
Quote from: green69rt on March 20, 2019, 08:21:20 AM
325-50-15  28" tall
15x10, 4 7/8 Back space
cdr
Quote from: 68ChargerJMP on March 20, 2019, 09:23:24 AM
325-50-15  28" tall
its just a stock bumper, I had to go out & look at the bumper bolts LOL, they are all there, but for some reason they dont show up in that picture.
cdr
You can see them in this picture, car is filthy got caught in the rain for 130 miles with Drag Radials, not fun.
68ChargerJMP
Quote from: cdr on March 20, 2019, 09:39:16 AM
325-50-15  28" tall
Gotcha. Thanks.
triple_green
I run the 275 60's on my 68. While it looks cool (raised the height 2 inches, it robs you of a little low end grunt too. It 28" tall and the stock tire being 26" tall. If you already have low gears then maybe this wont matter to you.
68 Charger 383 HP grandma car (the orignal 3X)
darbgnik
325-50-15  28" tall
CDR, you were my inspiration for ordering Mickey Thompson Sportsman S/R in28X12.00R15Lt, which converts to approximately LT305/55R15. Hoping they fit! I also ordered 26X10.00R15Lt which converts to be LT255/55R15, which is the size I have now on the front in Goodyears....
Pretty sure the minimum width they recommend for the rears in 8.5", so the should fit with an 8" rim.
Brad
