Antenna lead routing
Started by nitrousn, April 10, 2020, 08:32:04 PM
nitrousn
69 Charger under the dash how was the antenna lead run? Over or under the glove box and what was used to hold it in place? The antenna lead was cut off when I took the car apart 15 years ago. I would like to put it in its proper place.
Just like the rest of wiring going to that side
Davtona
Under the glove box on mine anyway. My 69 had 3 spring clips that attached it to the bottom of the metal dash frame as it went across. Any body know of a source for these?  Mine are not in that of good shape.  :2thumbs:
nitrousn
Quote from: Davtona on April 12, 2020, 12:02:32 PM
Thanks that is what I found today in a factory service manual. I only had one clip in the bag from when I took it apart 15 years ago. Once I saw the picture I knew where that clip could go. May of had more when new but who knows. I just wanted to put it back in the way it was built. Thanks again.
nitrousn
Quote from: Nacho-RT74 on April 12, 2020, 03:32:15 AM
Wrong but thanks for the guess.
