71 Charger Wiring Diagram
Started by Simonic, May 31, 2020, 11:27:02 AM
Simonic
Hi Gentlemen.
Would one of you have a copy of a wiring diagram please that i could look at?
I'm particulary interested in the taillight section.
Thank You
Mopar owner in the UK..
Simonic
it is pretty much interesting not to much ppl post the rear tail light section. This is from the 74 FSM which I colored. It is the same than 71/72 except for the gray wire for ground on pot metalhousings which is inexistant, because is grounded by chassis.
it's made very technical, not so easy to undertstand than earlier diagrams but I added some info on it
it'SPECIFICALLY the tail lights assembly, not the body harness between them and kick panel plug. The body harness gets aside the 4 wires to the tail lights, the blue wire to fuel sender and a pink wire for the trunk light
Simonic
71charger_fan
The factory wiring diagrams are scattered through the two volumes of the factory service manual. When it comes to the wiring diagrams on the '71 Charger, you'd do well to get a copy of the FSM. I've found a mistake or two (although I don't remember specifics) in the diagrams posted on line. I bought a good set of colored pencils and traced over the lines in the FSM to make them easier to follow. Unfortunately, my FSM is in the car at the body shop or I would scan the pages for you.
