440 Pulley/belt setup
Started by GrazerX, October 13, 2020, 12:27:28 PM
GrazerX
Only when I fitted a new alternator did I realize my pulley/belt setup is not right! I have one belt for water pump/ps pump and alternator (no AC).
The crank has a triple pulley. I presume the PS pump should be on a separate belt? Do I need a different mounting bracket so it sits further forward? Or a dual belt pulley? Any suggestions appreciated!
'68 Charger 440
'74 Camaro 383 Stroker
'19 Tesla Model X P100D
'19 Tesla Model 3 LR
cdr
WOW !!! does it overheat ? yes it should have a separate power stg belt, looks like Maybe the pulley on the stg pump is on backwards, it is offset. not sure without more pictures  or wrong pulley
Yeah, not much belt wrap on the WP...wonder how it pumps at all. Here's how it's supposed to be.
GrazerX
Doesn't overheat but it's pretty cold here in Scotland! Here's how the PS pump mounts:
'68 Charger 440
70 sublime
Yes it looks like if you can turn the pulley over on the power steering pump it would line up with the next groove on the crank pulley
timmycharger
Looks like you have everything there, just need a smaller belt for the alt/WP/Crank and separate one for the PS pump to crank..  :shruggy:
GrazerX
Quote from: 70 sublime on October 13, 2020, 02:43:17 PM
You think I can just flip that pulley?? That would be a suspiciously easy fix!
'68 Charger 440
cdr
Quote from: GrazerX on October 13, 2020, 03:34:21 PM
Thats the wrong pulley that is a GM pulley
cdr
70 sublime
I had a look at my car and my pulley has the spokes also
My car has a 383 from a 1971 donor car
70 sublime
My crank has a 2 groove pulley just like in the diagram John posted with the inside pulley having a smaller diameter than the out side pulley
GrazerX
Great thanks everyone. I'll have a look for that pulley from somewhere that isn't BPE - they charge a $140 fee for making an international payment!
Anyone know what belt sizes I need for the correct arrangement?
'68 Charger 440
GrazerX
Got the new PS pulley installed. Looks more like the thing - BUT - the PS pulley belt is rubbing on the WP pulley!! Looks like I need to change the WP pulley too? Any recommendations...
'68 Charger 440
68CoronetRT
http://store.440source.com/Pulleys-Belts/departments/15/
That'll have everything you need. Not sure if they ship international, I dont see why not.
GrazerX
Thanks, ordered.
All the ones on summit looked the same shape as my current one but the one on 440source looks like it will do the job  :2thumbs:
'68 Charger 440
GreenMachine
Quote from: GrazerX on October 25, 2020, 08:03:24 AM
I've only seen that water pump pulley on small blocks.
You can also try a narrower belt that rides deeper in the groove, like how it was on your original set up pic, and on the pics from 70 Sublime.
A part number starting with 17 is probably what you have now, try one starting with 15. Looks like the 17 is 15/32" (13 MM) wide and the 15 is 3/8" (10 MM) according to rockauto.com
https://www.rockauto.com/en/catalog/dodge,1968,charger,7.2l+440cid+v8,1078859,belt+drive,belt,8900
GrazerX
Latest problem!! Ordered a new water pump pulley from 440source. It's definitely the right shape to clear the PS pump belt BUT it's bigger than the last one and hits the crank pulley! The one that's on is 6.5" diameter and the new one is 6.75". Looks like every pulley is wrong - is the crank pulley wrong too?!
New pulley:
Old pulley:
No pulley:
'68 Charger 440
cdr
looks like the wrong lower pulley also,
GrazerX
Quote from: cdr on October 30, 2020, 01:35:16 PM
Yeah thought as much! New double groove crank pulley ordered from 440source - if that doesn't sort it I'm done!
'68 Charger 440
