cam choice
Started by flyinlow, March 14, 2021, 09:35:19 PM
flyinlow
Time to pick a cam for my Son's 505 build. 1970 Charger.  Garage elevation 1000 feet MSL.
440/505  4.25 stroke/4.350 bore
deck height 10.706
Mopar 452 alum. heads   84cc  stock
1.5 ratio Mancini roller tip rockers
10.3 CR
.045 quench
17cc dished pistons
performer RPM intake
780 Quickfuel carb
Hedman headers
4L60 transmission OD
close to stock converter
4:10 axle
Copper Cobras 28 inch tires
Used for cruising around in , burnouts, generally annoying people that are Twitter addicts' and occasional dragstrip .  Must live with power brakes. Long engine life ,normal maintenance. Wide torque band preferred.
Thinking about solid lifter flat tappet. EDM lifters.
Opinions please.
No comments on the cam, but I would vote to raise that axle gear.  Maybe 3.73.
The 4L60E has a really low 1st gear.  Much lower than a torqueflite.  That combo of 4L60E + 4.10 axle . . . the first gear ratio ends up like a torqueflite + 4.88 axle.
Even with the 4th overdrive gear, at 75 mph on the highway your combo will be revving up near 3000 RPM (with a non-locking converter) if you keep the 4.10 axle.  It's not a bad RPM by old muscle car standards but it's high by modern standards.
If the car was mine I might use 3.55 gears.  But I definitely like my gears on the tall side.  It takes a conservative cam & converter (at least for the motor size) to work with that setup.  And with a 4L60E trans, that 1st-2nd gear drop would get more annoying as the axle gear gets taller.
Challenger340
I as well would reconsider the Rear Gearing to 3.73 for sure.... possibly even 3.55's depending upon the actual diameter of the Cooper's.
The 4.25" Stroke eats Cam Duration @ .050.... consider the Comp Cams XS282S widened to a 112* LSA as a good baseline default Cam selection.
However, from there ?
and devoid of any actual Flow data on your Heads ?
IMO, there are very few hp/trq are to be gained using anything else more akin to just chasing your tail.
Only wimps wear Bowties !
flyinlow
The 4: 10 axle was in the car when my Son bought it. Put a 3.23 in it until we installed the OD Transmission. Yea the 4:10 with the 3.06 first gear helped the smog motor that was in it get moving. I suggested he replace the 8 3/4 with an S60 . 3.73 sounds good.
I have a noisy 3.55 in my Charger with the A518. Maybe I can get a package deal on two S60's with 3.73 ratio  :lol:
flyinlow
Quote from: Challenger340 on March 15, 2021, 09:14:33 AM
I was looking at that cam last night. Why change to 112* LSA?  Looked at the XS274s also for drivability.
So as a rule of thumb for every 50 cu.in. you go up you can increase your duration by one step and keep the drivability about the same?
I like the xs282 as well. The "stockish" converter leaves alot to the imagination. 4l60s had alot of options when it comes to stock. Depending on how tight it actually is and swinging a 4.25 crank around, i would personally go up a size from the 282 with a 4.10 gear having an overdrive.
flyinlow
Quote from: c00nhunterjoe on March 15, 2021, 09:22:30 PM
Well that's 3 votes for the xs282s.
The 4l60 was a Silver State Kit . Picked up new but stored for 5 years from a guy who sold the car for financial reasons before he installed it and he gave me a price I could not turn down. Don't know the stall. 2400 RPM with the old motor ? It could spin the 275/60 Coopers but it worked at it. I know we have some drive train upgrades to do if he ever wants stickier tires.
:Twocents:
Building a big stroker to blow the tires off, and adding sticky tires?  Opposing goals.
Tell him to get rear tires that look as big & cool as he wants but don't go for sticky compounds/models.  He will have more fun.  The grip will be tolerable without breaking everything.
Besides, any modern tire might as well be a drag slick by 1960s-70s standards.  It's all about perspective.
Just my opinion.
Challenger340
Quote from: flyinlow on March 15, 2021, 03:28:56 PM
So as a rule of thumb for every 50 cumin, you go up, you can increase your duration by one step and keep the drivability about the same?
The 282 will be easily streetable over the 4.250" arm, again here.... Stroke eats Cam duration for breakfast, and the 274 would be too small.
112* lsa is mainly to improve Pwr Brake vacuum, however, widening the lsa also flattens/widens the Torque curve slightly,
but that said,
unless he plans on riding the brakes constantly in parking lots the 110 lsa will work for normal driving.
flyinlow
Having trouble finding Comp Cam solid lifter cams in stock. Comp cams has none ,and no blanks for a custom.
Questions:
Is nitriding still desirable?
Are Johnson lifters still the best choice ?
Is a three bolt cam required . If I use ARP bolt /red Loctite?
Eldovert
Quote from: flyinlow on March 17, 2021, 12:52:36 PM
Questions:
Just get a hydraulic (if they have them)and run solids
I hear Comp is getting other companies to help with cams (staffing issues?)
flyinlow
Thanks Nacho I found that earlier ,it is a single bolt.
Hydrualics are more available.
Will check with Comp and see if I buy one of there cams if I can send it in for nitriding.  :shruggy:
Eldovert
Not quite sure of the details..sounds like Comp bought Edelbrock and they are moving operations to Mississippi..that would explain the lack of stock at Comp.
flyinlow
If I look at hydraulic roller cams
Hughes recommended SER3842bl-10  238/242 @ .050 , .540/.550 lift with 1.5 ratio   110 LSA   this cam is not billet and they said and does not require a bronze or treated gear
Comp23-712-9  xr286hr-10 grind    236/242  @.050 , .544/.544 lift  1.5 ratio, 110LSA  , billet cam
both in stock
opinions?
Challenger340
Quote from: flyinlow on March 19, 2021, 12:17:01 AM
both in stock
opinions?
Why look at HR Cams ?
We've basically discontinued using HR's now entirely in BB Mopars ..... because without Bushing the Lifter Bores in the BB Mopar Blocks($1,000 hit) for patent HR Lifter sealing against the higher V/Spring pressure requirement ?
We just could never prove any power increases on the Dyno with HR's in NON-Bushed 50 year old worn Blocks/Lifter Bores to justify the added expense nor full range rpm stability ?
Bottom line = Lifter Bores are too short in a BB Mopar with the Oil Gallery positioned far to low in that 50 year old BB Mopars worn Lifter Bores for patent sealing against the higher HR V/Spring pressures in most 50 years old worn Blocks ?
That said...
Even a blind chicken gets the odd kernel of corn.....
and you too may install an HR Cam in your BB Mopar without Bushing the Lifter Bores and get lucky... works fine ? or so you think ?
All I'm saying is this:
1.) we Dyno every BB Mopar Engine before it leaves.... and we don't use an HR Cam in them anymore unless the customer opts for us to bush the Lifter Bores as well($1,000)
2.) by the time we bush the Lifter Bores in the BB Mopar for patent HR usage..... we never found sufficient power on the Dyno from the HR Cams to justify the added expense.... let be sufficiently above a well selected Solid Flat Tappet Cam of the same Size....or even just skipping Bushing the Lifter Bores entirely and running a Tight Lash Mechanical STREET Roller Cam.... which DOES make waaaay more power !
But as always...
You believe whatever you want and do as you think is best.... it's YOUR Engine.
If you do opt for a Solid Flat Tappet Cam ? get it Nitrided, and use an EDM Lifter (NON Topline Johnson as they are gone now I believe)
IMO....
if you do want Roller.? ... skip the HR garbage and go straight to a Tight Lash STREET profile Mechanical Roller....
which,
the STREET Mechanical Roller Cams are also known for curing all forms of depression and anxiety, and requiring a 2X4 to wipe the smile off even the most ardent Drag Racer's face !
Q5XX29
I run a Bullet cams flat-tappet solid in a 500 B engine, with 251/255 duration @ 0.050, 570/580 gross lift, 110 LSA, full weight '68 Charger with 3.91 gears and 3800 stall, runs 11.40s all night in the hot summer with DA of 3,000, on drag radials. Oh yeah, power brakes and no vacuum issues. Mildly ported Edelbrock heads and Mopar M1 intake. Sees mostly street use, where it runs reliable and cool.
dakota_gt on Instagram
BSB67
Quote from: Q5XX29 on March 21, 2021, 04:01:45 PM
Nice.  60 ft 1.70s?, mph 119 ish?
11.68 @ 120.2 mph
Q5XX29
Thank you.  60' times on a good run are 1.56-1.59 range. It launches great. Mph, disappointingly, is only 116-117. Maybe you have some idea why that might be?
Challenger340
Quote from: Q5XX29 on March 23, 2021, 10:27:22 PM
Just curious.... what rpm are you shifting at ? and through the traps ?
Q5XX29
Quote from: Challenger340 on March 24, 2021, 08:36:30 AM
Have tried shifting anywhere from 5900 to 6200, and it doesn't seem to make too much difference. Its my 20 year-old son's Charger, but I've driven it downtrack several times too. If I recall correctly, I thought it was getting fairly close to redline again going through the traps, because I remember thinking we couldn't go up much more than maybe 4.10s.. but now that I run the tire/gear calculator, with the 29.5" tall tires we run at the dragstip, it should be only at about 5350 at 117 mph, so could we be losing THAT much through the converter?  Sorry to the OP for the thread hijack.
Q5XX29
Quote from: Q5XX29 on March 24, 2021, 04:49:36 PM
Have tried shifting anywhere from 5900 to 6200, and it doesn't seem to make too much difference. Its my 20 year-old son's Charger, but I've driven it downtrack several times too. If I recall correctly, I thought it was getting fairly close to redline again going through the traps, because I remember thinking we couldn't go up much more than maybe 4.10s..  According to a tire/gear calculator, with my 27.6" tall tires, I should be at around 5700-5800 at 117 rpm.
edited to correct for my tire size comment
flyinlow
Quote from: Q5XX29 link=topic=139531.msg1727891#msg1727891 date=161655644
/quote]
No worry's.  It was interesting reading.
Challenger340
I'm thinking your stellar 60ft times ? are coming at least somewhat at the expense of patent rotary flow/closer to lockup Convertor function of that Convertor in the Heavy car ?
just say'in....
FULL stall is 100% axial flow and 0% rotary flow in the Convertor....
and as the rear wheels turn faster and faster....
the Convertor should try to transmit more and more to the wheels as it reverses Torque Multiplication and approaches 3,4,5% ? axial flow and transmits 95% rotary flow ?
Don't SHOOT me for the readers digest version.... far more going on obviously just simplified for conversation.
No matter....
60 ft times are very important to E.T. at the Drag Strip because anything GAINED or LOST in 60ft time you can almost DOUBLE off or on to the E.T.
If you want MORE mph at the traps ?
the trick will be to finding a Convertor capable of more efficient closer to lock up at mph.... whilst still capable of the low 60ft times that YOU DO NOT WANT TO LOSE !
let me guess here....
any chance your Convertor is a store bought stocking unit and may be a little too loose for the Heavy Car ?
That said,
It can get pretty expensive opting for custom convertors trying for more mph and maintaining that all important to E.T. 60ft characteristic ?
IMO, 4.10's on the 29.5's is puss... stay there !
