wiper motor
Started by pistolgrip, June 10, 2021, 10:44:56 AM
pistolgrip
i have a 74 charger. i installed a new aftermarket wiring harness. my problem is the wiring on the wiper motor. i had to cut off the factory plug. (no bulk head). the wiper switch has a red, green, brown, blue, and gray. i know the red is 12 volts and the gray goes to the washer pump. can anyone tell or show me where the blue, green and brown and what wires they go to on the motor?
thanks in advance...
Gray washer pump? No way. Gray is oil sender. Washer pump is brown. On a 74 is on forward light harness
Wiper plug gets two browns ( one traced ), pink, red, blue and green.
Motor is two or three speeds?
This is 71 onto a 2 speeds. Plug disposition changes at switch from 72/74, but wiring is the same.
I guess you actually need to know what wire arrives to what cavity on motor plugs?
3 speeds gets the wire attached to motor. Unless you removed from welding points I don't thing you need a diagram?
