Forward light harness
Started by Crazy440, August 14, 2005, 01:55:05 PM
Crazy440
Been checking around for a Forward light harness,for my 73.   All I find is:
1. 74 Plymouth "B" body
2. 72 Dodge/Plymouth "B" body
3. 71 Charger
4. 73 "B" body, 4 door and Station Wagon
Nothing for a 73 Charger.
Will any of the above fit, correctly?
I used to have a handle on life....but it broke off.
71 Charger has parking plugs different, also washer windhield bottle on different location... I don't know about sidemarkers sockets.
72 is the same about the windshield washer reservoir.
I would go with 73 B body, with same location of every stuff, and same sockets etc...
Crazy440
The only 73 B body that I found was for 73 "B" body, 4 door and Station Wagon.   Are you saying that this will work for the Charger?   I don't want to buy something, that I will have to re-work, to make it fit.
Thanks for the reply.
Is the closest I can see on options you posted... 73 Coronet also has double Beams on front, the inner fenders, firewall and frames are the same, washer bottle in fact also is the same, Battery position is the same. My bulkhead on firewall was a 73 Coronet donor. Sidemarkers are the same... there wasn't hideaway options since 73, horns I think were the same on same locations. I don't see anything that could be different on that, but is what I can see from a distance.
I don't know about parking lights plugs. 71 were bullet kind and since 72 on chargers where spades kind, but I don't know on rest of B bodies.
