denso alternator wiring
Started by Hemidog, April 01, 2009, 03:26:33 PM
Hemidog
I'm not quite sure how to wire these two wires ( the indicator lamp wire will not be used)
From my Painless wiring there goes a blue wire to the alternator that called "alternator exciter", does this go to the "sense" or "ignition" ? and the other goes to the "batt" position on the starter relay?  :shruggy:
mikepmcs
Hemidog
Sorry, that didn't give me the answers I was looking for, and I use a voltmeter.
Nacho? Plum?
I have known about ppl mounting some chebbys alts on Mopars ( very tipical down here ), and I have seen some bulbs mounted in "series" with the alternator. Ppl told me thats an "exciter". Normally is used a sidemarker plug and bulb to make that.
never have studied that really
Hemidog
Hey Nacho, wikipedia says this: "The wire supplying the field current is often referred to as the "exciter" wire"
Does that make any sense? This is an alternator with a internal volt-regulator.
Hemidog
Searched some more and got my anwers:
-Ignition wire to blue "exciter" wire that usually goes to the voltage regulator.
-Sense wire to starter relay stud.
On most GM swaps the sense wire is usually just jumpered over to the battery post on the alternator, also a diode needs to be placed inline on the "exciter" wire, otherwise the engine won't shut off. (feedback through the ignition switch)
