Interior Install
Started by comet_666, July 18, 2015, 08:54:07 AM
comet_666
Have a few questions on the 69 interior install.
Rear window shark teeth things. I think I understand how they go in but could not get the black "T" things to turn and lock it in. Are these screwed in first?
The side shark teeth on the rear window having same issue with.
Plastic door vapor barrier. Can I just use any plastic? Is it glued on? Also what should it not cover up?
Rear upper door pad supports. There is a left and right, anyone have a pic of how they go in? Matching up screw holes only works when there aren't extras there   ;)
And last..what is this? pic attached
green69rt
Is the angle piece all covered in zinc, no polished surfaces?   I could't find anything in my parts that looked like that.   Did you take it off the car or did it arrive loose?  Other Mopars use different hardware to hang the upper door pads, maybe it is for another model of car?
Charger-Bodie
Quote from: comet_666 on July 18, 2015, 08:54:07 AM
Holds the lower rear window trim. Inside, Rear parcel shelf slides under it.
comet_666
Sweet! Any ideas on what screws go in there?
Charger-Bodie
Same style as the ones that hold the upper door pad plates.
comet_666
My next question was what screws hold those on lol.
BananaDan
For the vapor barrier, I took the advice of Bill440RT and used hardware store plastic sheeting. I can't remember the name of the tacky stuff I used to adhere the plastic sheet but I should have a box in my basement. I can check tonight.
comet_666
Ok, and I saw in the manual how it installs. Does the back also get the plastic?
70 sublime
comet_666
Pulled this off GYC. Shows how this rear upper bracket is attached. Manual does not really get a good look at it.
comet_666
Now if I could zoom in and see the screws...guess ill use whatever fits.
keepat
They are 5/8" long #8 pan heads.
I hope this helps!
Pat
comet_666
BananaDan
comet_666
Ah ha!
Thanks BananaDan !
HeavyFuel
HeavyFuel
When you attach the plastic, be sure to tuck the bottom into the horizontal slot in the side panel, which will prevent water from shedding into your interior.
comet_666
Oh man thanks HeavyFuel! These pics really help!
HeavyFuel
Those clips that hold the 'shark teeth' strip are kinda weird.   You just open them up a little bit with a flat tip screwdriver or something after putting the strip in place.
I also found a better pic of the rear trim piece and how it works with the corner.
comet_666
Oh great pics! I messed around with that area and was slightly baffled.
Thanks a million!
comet_666
Pics were a huge help!  Thanks all!
Re mounted seats today to try and figure out where I want shifter.
comet_666
Also was getting a rough idea for my 3 point retractable XV seat belts.
comet_666
Short end of seat belt that mounts to the hump does not seem to make it around the buddy seat. Reached out to XV for guidance on that.
comet_666
I unboxed my interior door panels and noticed they need some work? Looks like I have to cut all the holes out for the door handles and clips?
For damn near $500 this should have been already done.
comet_666
Installed rear panels las night, what a freaking pain in the ass. They have to slide under the chrome trim so you cant put clips on the top. The Legendary door panels ...well lets just say when prepping them I was told to pull the little cardboard plugs all the way out till the white foam, then put the clips in. Well some clips will buldge out the doop panel so I guess you just deal with it. Also the upper pads, the screw hole facing the door jamb is slightly off and does not look correct. These are the origional pads but not the origional door jamb or quarter.
