low miles 500.
Started by Brock Samson, June 07, 2008, 02:06:14 PM
69_500
It should, but the 500's were an early year car. Last one was built before jan 1 1969 though.
hemigeno
All 1969 383-4 and 440-4 (HP) cars sold new in California were supposed to be coded with the N97 Noise Reduction Package.  Hemi's apparently were not required to have that coded, for whatever reason - maybe because they already had extra mufflers/resonators?    :scratchchin:  I don't know about 6-pack 'Bees or 'Runners in 1969, as the docs I dug through didn't mention anything about engine code E87s.  I'm also pretty clueless about what they required for the 1970 or other model years.
Best I can tell, the only things included in that package for 1969 were a dual-snorkel air cleaner, and the turn-down exhaust tips rather than the chrome tips.  The '69 Parts Book lists two different part numbers for the N97 tail pipes, one number for cars built up to 10/15/68, and one for N97 cars built after 10/15/68.  Could be that the difference is how the tips were cut - squared off with the pipe, or almost parallel with the ground??  :shruggy:  The engineering diagrams and service manual diagrams for single exhausts and station wagons all sorta look like the pipes were cut parallel with the ground, similar to how this C500's tail pipes look - but I wouldn't hold those diagrams out as the absolute example of how things should be.  I think 66-67 Chargers had their tips cut parallel with the ground too, but it's been a while since I've looked at that detail on a "real" car.
:shruggy:
69_500
Thanks for the correction Gene. See what happens when I speak without checking things first. N97 not N95.  :brickwall:
hemigeno
No biggie, I had to look that one up myself.  Not a code seen very much, is it?
472 R/T SE
Can always count on you Geno, & Chris.  THANKS.
Good gravy, I don't know how much time I spent trying to find N95 with '69 models.
hemi68charger
Quote from: hemigeno on June 11, 2008, 08:33:41 PM
:shruggy:
On this note.. My first '70 v-code Charger R/T built in St. Louis had one of it's original tailpipes and it was cut squared off.. Not sure it means anything, but it shows that the '70 model  had the squared... Of course, I'm making the BIG assumption based on what I knew then that it was the original tailpipe for it surely looked as if it was..........
Houston Mopar Club Connection
RAC95054
Quote from: hemigeno on June 11, 2008, 08:55:56 PM
My '70 GTX was an original Calif. car, and has the N95 and N97 codes (but more importantly, the N96 Air Grabber!).  It lists N41 on the fender tag (dual exhaust), but no N42 for the chrome tips.  It still even has the original turn down tailpipe hangers!  But the original exhaust is long gone.  From other Calif. bought cars I have seen at shows out here, they all have the bent turn downs, and not a "sliced" pipe, as the C500 has, as I recall (I'll look into some pics I have).  Even the '71 Chargers and GTXs with the bullitt tips ended up with turn downs instead of the cool tips (just saw one of each at the last show here).
Play: Work that you enjoy doing for nothing.   -Evan Esar
UFO
Here's a scan from a sales brochure.
69_500
Went through all the broadcast sheets I have for Charger 500's and none of the one's I have copies of have N97 on them either. Makes me wonder what my dad's old Red HEMI 500 was coded for. I know it had a sheet when he had the car, but no chance at looking at it now as I haven't seen hide nor hair of that car in 20 years now. I do know it was a California car though.
nascarxx29
That Ex Pete Haldiman car is a far as I know still here in NJ.Mike V promised it to his kid to give it to his kid.To drive.Not to bad for a first trime driver to start off with
1969 R4 Daytona XX29L9B410772
1970 Coronet RT WS23UOA224126
69_500
Thats where it is, but have yet to be able to talk them into letting me come look at the car.
nascarxx29
hergfest
Um, I don't know what you guys are talking about but N95 and N97 came in 1970.  No 1969 model year car would have either code.  If that R4 500 is the same car I thinki it is, its an original owner car.
nascarxx29
I have the ad when it was for sale by Pete Haldiman this isnt the one on the trailer.Its also a factory AT trans car .I contacted the owner through a friend of mine in a nearby town to the red hemi 500.To notify the trans was available.Never heard if the owner went to retrieve it
472 R/T SE
Quote from: hergfest on June 15, 2008, 01:22:16 AM
I PMed Chris asking about the N95 cause I was always under the impression it wasn't until '70.  I have always been impressed with Danny's knowledge of these cars and had no reason to doubt him.  But had to ask Chris to double check.
Quote from: Just 6T9 CHGR
What I do know is that for 69 there was only the turn downs and the larger dual snorkel air cleaner (fugly "ribbed" one....not the nice & smooth 70 style) coded N97 for the "Noise Reduction Package"
Also on the 69 BS there really isnt a spot for the N97 either.....under the "N" codes there would be a blank box with the #7 typed in (no hardcopied #9 above it to signify N97)
Hope it helps
Chris
I think Chris' explanation and Geno's, along with N97 showed in Galens' white book for '69 holds more weight than any 2 post NEWBIE.  :shruggy:
69_500
Don't worry if you stick around long enough, you'll see that I make plenty of mistakes. Most of the time I should slow down and look things up before I type, but I guess it right some times and rely on that too much. Just goes to show that I'm just like everyone else, FAR FROM PERFET.  :yesnod:
Just don't tell my wife I said that she would have a cow. She says I never admit when I'm wrong.
hemigeno
Quote from: 472 R/T SE on June 15, 2008, 04:27:44 PM
Hope it helps
Chris
As some added weight to the N97 question for 1969, I found three mentions of N97 in the piles of paperwork around the office here.  Two of the doc's show that the numeral "7" is typed in box 36 of Line 9 on the '69 Broadcast Sheets to indicate when N97 is supposed to be included.  All three of the doc's with that information on them are dated 6/21/68, meaning that the code was in place for the entire '69 model year production run.
Still haven't found anything that explicitly walks through what is included with the NRP, but Chris' explanation is the same as what I've recalled anyway.
:Twocents:
UFO
In the '69 parts book there is mention of NRP in the tailpipe section 11-09-3.
There seems to be a change of some kind on oct-15-68 as there is an up to and after.
C5X DAYTONA
Quote from: 69_500 on June 08, 2008, 03:14:59 PM
Nice looking ride.
R4 red, white interior, white tail stripe, with A/C and an 8 track. checked all the information I have, and didn't come up with a VIN to match the car though. Love the turn down tips on the exhaust too, could possibly be a N95 car?
I like how the bezels are body color too and not stripe color.
This is Bill Conn's 500 vin XX29L9B225531.  His dad Ernie purchased it new for his wife.    I had just did the headliner and installed a new windshield and fixed all the electrical in this car just before these pictures.
Caution.... Low flying aircraft.
nascarxx29
hergfest
Yep, and it got shipped overseas.  This was the car I was trying to buy but couldn't find a buyer for my 500.
C5X DAYTONA
Quote from: hergfest on September 28, 2009, 12:57:19 AM
Hay Gary,  How did the road test go?   Are you all ready?  Talked to Kaey and trans is not done in his car yet.  I know he works fast but 3 weeks to go and 5000+ miles to travel...   I keep trying to get more guys to drive their cars but they are all afraid.   :brickwall:
