318 vs Big Block
Started by AKHeilman, March 17, 2009, 09:55:32 PM
AKHeilman
Hey guys, hope you can help me. I have a 71 Charger SE with a 318/904. Can you talk about the pros and cons of upgrading to a BB/727? How much am I going to spend to get very good HP from the 318 as compared to getting equal horses or more from a big block? How is mounting the new engine & trans in the old mounts gonna work out? Can I reuse the stock AC parts? I found a stock 400/727 on CL for $1000 for both. I want a daily driver or at least every weekend driver. I have a steady income with only about $800 on me now, and I have to fix up the interior and do some frame rail and floor pan fabricating. I want to keep the car from the time with some new modern stuff. Pretty sure it's numbers matching as is. I'm also pretty sure it's a 8 3/4 rear, unless you guys know that that wouldn't come with the E/T combo. Thanks for the help. Below is the VIN & what I can read from the half of the fender tag that isn't rusted away.
WP29G1A143###
################143256 359 030
                   L37
##Y     U                            H51
GY9     E5Y#     GY4     105     142903
E44     D31     WP29   G1A      143###
"Equal opportunity means everyone will have a fair chance at being incompetent." Laurence J. Peter
green69rt
Quote from: AKHeilman on March 17, 2009, 09:55:32 PM
WP29G1A143###
                   L37
##Y     U                            H51
This is just my take on this and will follow this thread to see what others have to say.  If you just want a few HP then the normal route is cam, carb, headers.  But you can really spend a lot of money real fast and not get much increase from your 318.  The only real way to get cheap HP is with cubic inches.  Try to find a good used 360 CID engine.  I think it will match up to the 904.  Add a four bbl carb if it doesn't have one, engine mounts, maybe some other fittings and you're there.  If you want more than that you're talking about more than $800.  (I really wonder if you can do what I said for the $800, it will take some scrounging?)
Going the 400 route would work also but I wonder about the adaption of it to your car. Does it come with such stuff as alternator, power steering, and other brackets, distributor.  You almost certainly will need carb linkage, shifter linkage, drive shaft mods, exhaust, etc,etc,etc.  Upgrading to a big block is not a direct swap.
What do others have to say?  This is the old hot rodders dilemma.  Max power, lowest cost.
charger_cody
Ok here is what i did, i have a 73 that had a 318 in it. I found an ooooolllllllllllllllllldddddddd rusted out POS 81 dodge van. took the 360 out of it and made it real nice. i drove the car with the 318 in it, and it didnt put out very many horses nor torque. So i say what the guy above me said. find a cheap 360 and put a new cam, 4-barrel, rocker arms and blah blah blah.
Charger1973
Id keep the 318 and just drive it.  Use the money for more important things like the frame repair you mentioned.  BTW the front clip on your car looks to be from a 73 or 74 Charger...  most likely a 74 due to the lack of cowl vents on the hood.
KS71owner
I warmed up my 318 with the Edelbrock Performer RPM package (cam, intake, carb) and a new set of heads and headers. Put in an electronic ignition system too. Had my 904 rebuilt a few years ago and new mounts put in for everything. It doesn't make gobs of power but it does make for a great cruising car that can go long distances with no problem. For me it's a great solution until I can afford to either buy a new MP crate 360 or upgrade to a BB setup.
1BAD68
For a nice cruiser, you cant go wrong with the 318 or any of the small blocks for that matter. They can make some decent power and torque.
I went around and around with that decision for awhile and decided to stick money into my 318 mainly because it was original to my car and I like the way small block cars handle.
I ended up stroking it, .30 over and a 4" crank comes out to like a 392 or something.
It gets great mileage, revs quick, smokes the crap out of the tires and looks pretty much stock, I love it.
It was fairly economical too costing just under 2 grand with all new pistons, rods, crank, machining, gaskets and assembly.
I still run the stock heads that I ported, someday I nice set of heads on this thing and it will really wake up.
Foreman72
losts of threads about this my 318 brother... :cheers: 2 the 318...i'd hold on to it...u can pull upwards of 400 hp out of it w/o breaking the bank...check out the following...good luck man :2thumbs:
http://www.dodgecharger.com/forum/index.php/topic,53264.0.html
Eric "Foreman"
Previous: 1972 Dodge Charger
Current: 2002 Volvo S60
"The steps of a man are ordered by the LORD, and He delights in his way. Though he fall, he shall not be utterly cast down; For the LORD upholds him with His hand.
=Psalm 37:23-24=
"But store up for yourselves treasures in heaven..."
=Matthew 6:19-21=
:pat
wayfast1500
someone was telling me the only difference between a 318 and 360 is the heads?  I do know the 360 heads with some other bolt ons can get it in the 400hp range as stated above.
TUFCAT
Build a big block!!  - unless it was available with a 340 (then make a 340 clone).
Take it from me..... 318 CARS GET NO RESPECT!! - even the original ones.
When I pop my hood, some people just walk away, and I hear them say "it's only a 318".  :'(
green69rt
Quote from: Charger1973 on March 17, 2009, 10:48:09 PM
All things considered, I have to agree with this guy.  Get the car in shape first then add the horses.  This also gives you time to look for the best deal on the bigger engine.  Good things come to those that wait.
green69rt
Quote from: wayfast1500 on March 18, 2009, 03:31:57 PM
360 also has larger mains on the crank. 273-318-340-360 all have the same factory rod length.
There's a whole world out there on designing strokers but they are not cheap and you'r not going to get it done for $800.
horsepower < sheetmetal repair
sheetmetal repair < frame repair
Foreman72
Quote from: TUFCAT on March 18, 2009, 03:46:06 PM
Build a big block!!  - unless it was available with a 340 (then make a 340 clone).  :2thumbs:
Take it from me..... 318 CARS GET NO RESPECT, even the original ones.
When I pop my hood, some people just walk away, and I hear them say "it's only a 318". :eek2:
that sucks man...nothing wrong with a 318...i don;t wanna just hop the wagon and go BB...thats not what its about
Eric "Foreman"
=Psalm 37:23-24=
=Matthew 6:19-21=
:pat
mopar_nut_440_6
I always say " There is no replacement for displacement."  Of course, new technology seems to be coming close!
You will spend more money trying to get a small block to pull like a big block. I had a 318 Charger once and built a mild 360 for it thinking this was the way to go. I ended up building a mild 440 for the same amount as the 360 cost and the difference was night and day. The Charger is also a heavy car and would benefit from the extra torque the big block will provide. This is just my opinion based on my personal experiences.
Cheers,
James
1968 Charger R/T 440
2004 Dodge Ram 2500 680 HP Cummins with attitude
TUFCAT
I agree. With todays' engine technology and parts availability, its possible for someone to build a very good performing 318...and I'm not even talking about what a 360 can do!  You might even embarrass a lot of people.  Many still underestimate what can be done with good engine building skills.
I'll betcha firefighter3931 can build a 318 that runs like a 340! :2thumbs:   I've been getting advice from him on my 383 build for the Coronet. :icon_smile_wink:
69bronzeT5
I'm gonna build a 318 that runs like a 340 :D
1969 Charger R/T, 1970 Challenger R/T, 1970 AAR Cuda, 1971 Charger Super Bee x3, 1973 Road Runner, 1973 Plymouth Duster, 1974 D200, 2008 Challenger SRT8
TUFCAT
Quote from: 69bronzeT5 on March 18, 2009, 05:44:20 PM
.....then you better listen to Ron (firefighter)!  :2thumbs:
69bronzeT5
Oh I will. For now it's getting a new intake and carb with the Hooker Comp. headers that are on it. Sometime it will get a rebuild. ;)
mikesbbody
If the car drives then stick with the 318 and fix what needs to be fixed then go with the BB when you have the money. You say you can get a 400? they make great strokers...nothing wrong with a 318 but i personally prefer BB's
Back N Black
Hey Tuff, nice engine bay! Can we see more pics of your Coronet. I like 318's, The majority of guy at car shows don't mine a 318 or any small block, they appreciate the work and effort put in the cars. There are a few numbers guy that lurk at car shows that turn up their noses.
AKHeilman
Thanks for all the responses guys! I guess you're right about getting the frame ready first. The biggest problem is the LR frame rail that's basically not even there anymore. What is recommended for repairing (building from scratch) the rail? The guy who had it before me had done some welding on it, but there are drips and the patch doesn't extend near far enough to support the spring shackle. Should I remove what he has and start over? Should it be made from one piece bent to shape, three pieces welded at right angles, or two pieces in an "L" shape? How about the prefab pieces from Auto Rust Technicians? Tell me what you think.
TUFCAT
Quote from: Back N Black on March 18, 2009, 05:56:17 PM
Thanks BNB....I could post lots of pics of my car - but its a Charger site so I try to resist.:icon_smile_wink:  On a 318 thread I figured a shot of a Coronet engine bay wouldn't be so inappropriate.  :D
Anyway ...here's another one (since you asked). :icon_smile_tongue:
Back N Black
No sweat on posting Coronet pics, its a Mopar after all. Not like its a 4X4 deloran. love the color.  :2thumbs:
green69rt
Quote from: AKHeilman on March 18, 2009, 06:31:20 PM
On replacing the frame, there's nothing like new metal.  From experience - these things seem to grow once started.  Just plan on replacing the rail and maybe the spring perch (just because it's hard to separate from the rail.  Then the trunk floor can be patched or replaced.  And don't be afraid of adding stiffeners to the body (torque boxes, and rail extensions, you can weld right?)  Also understand that this is not a 4 hour job, your car will be garage bound for a while.  Get some advice from friends or builders near you, most don't mind sharing their knowledge.  That's what hot rodding is about!!
why don't you say them if they pop theirs hoods and you say OOOH, IS A 4 CILINDER!!!! I have two of those linked in V shape
