What would cause....
Started by paul1966, March 01, 2006, 01:01:42 PM
paul1966
What would cause my car to act as though it wants to die when I make a stop.  My  engine seems like it wants to die when I stop.  It is not always a sudden stop, here recently every stop I make it acts like that.  I have a new fuel pump, and new fuel filter, and a new carb.  Could it be crud in the tank?
Thanks much,
    Paul
NYCMille
Do you have electronic ignition?
paul1966
No, I have not got there yet.  Still have the old points.  You think they need to be re-gaped?
blackcharger
Quote from: paul1966 on March 01, 2006, 01:49:01 PM
wouldn't hurt to check the points. Is the fuel level in your carb correct, Idle speed?
Dave
BigBlockSam
Quotefuel level in your carb
:yesnod:
deputycrawford
Im thinking fuel level in carb too. Mine does it on panic stops. But then I have a large bowled Demon carb on a car I drag alot. You might be uncovering your jets when you stop the car. Its  just a thought.
If it ain't wide open; it ain't running.        Rule number one in motocross racing: Pin it; row the gear box; and wait until you hit something.     At work my motto is: If you need me, call someone else.
fuel level...---floaters---
leak on bowls...
rich mixture...
delayed timming...
I was dealing with that. now I have rarelly a backfire
It could be also a higher pressure on gas pump... Gas pumps have a small hole at a side of body what is to ventilation. If is dirty or clogged will get more pressure that can be overflow the carb.
BigBlockSam
why would rich mixture cause that?
paul1966
I will check the fuel level in the carb.  Thanks much.
Paul
4402tuff4u
I would of guessed it has something to do with vacuum. That shows you how much I know about engine work. Do you have power brakes?  Welcome aboard.  :wave: You have pictures of your ride? :icon_smile_big:
"Mother should I trust the government?........... Pink Floyd "Mother"
paul1966
Now power brakes, I do have.  But I still have the drums all around also.
Paul
could be a leak in the booster or a drop in vacuum as the brakes are applied
Steve P.
That's what I was thinking.. Do you hear a sucking sound when you are just sitting in your driveway running with your foot on the brake peddle??  Is there any change in the RPM when you step on the brake at idle?? If so, have a buddy pinch your vac. hose with some long needle nosed pliers and make the same test again.
My daughters 84' Pontiac has a leaky power brake booster. It is only noticeable when it's cold. BUT WHEN IT"S COLD,,,, The seal leaks bad enough to stall her out..
And before anyone gives me grief,, It's not mine nor is it on the road!!!!
Steve P.
Holiday, Florida
paul1966
Changed the pionts, and the problem is fixed?  But Why?  I was thinking that like you guys said that it was the float in the carb, but I did not mess with that.  Just changed the points and everything was good?
I would like to know why if anyone knows.
Thanks again for all the help,
Paul
are the bushings worn in the dist ?
the shaft could be sitting at one side at idle & with RPM it may straighten up & run on center
paul1966
No, it is a new distributor, but it did not fix the problem.  I have not messed with the float in the carb, but I am thinking it is a vacum leak somewhere.  When one purchases a new carb, do you usually have to adjust the float?
Thanks Much,
Paul
