Pinion snubber question
Started by C500, March 17, 2020, 04:03:57 PM
C500
Guys - can someone please post a pic of the factory pinion snubber for a 69 with 8 3/4 rear. Seems there are a few different options for the 8 3/4.
Cheers.
"An aggressive exterior with power to match was enough to pull in the performance boys-especially when abetted by a pair of pipes blaring out the back, and brawny red-sidewall rubber hitting the pavement."
"........the four speed box changes cogs with the precision of a sharp axe striking soft pine."
Birdflu
Which carrier housing are you referring to...'742 or '489? The pinion snubber brackets differ between them.
Quote from: Birdflu on March 17, 2020, 11:06:51 PM
Eeehm, no, they are the same per what I know.
Stock
Adjustable MP
Adjustable aftermarket
I think you can find diff stock pieces ( more flat or not ) due upgrades made along the years for reinforcement but not due the 3rd member number.
Birdflu
Here's a couple of pictures showing the two types of OE pinion snubbers for the 8 3/4" carrier housing. Though they share the same bolt pattern, they are noticeably different. Now I cannot elaborate on whether, during the '69 production year, the pinion snubbers were changed based on a certain date, or whether the change was made when they discontinued using the '742 housing vs. the '489 housing. All I can tell you is EVERY single '742 carrier housing that I have in the shop has the longer pinion snubber and ALL the '489 carrier housings have the shorter design. There are probably 30-40 of each separated on two pallets in the shop. I do believe, as Nacho has stated, since the bolt pattern is the same, that is why we've never seen the aftermarket differentiate between the two. You decide. If you need one, we've got plenty!  :icon_smile_big:
First pic - '742 on left, '489 on right.
Second pic - '742 on top, '489 on bottom.
:2thumbs:
yes, maybe due the year ( diff distance with body ), but not due the carrier. At least what Dr.Diff mentioned on a similar thread at Moparts ( diff years but not carriers ), when I made the search. So I just can say what I have found LOL
since 742 was replaced by the 489 as far I know, then maybe that's the reason why they are different? :shruggy: and the 742 and 489 difference is a coincidence ? :shruggy: I think 742 and 489 never lived together between them. Or did they?
C500
Hi guys... just seen the replies to this thread, thanks for all the input. Will check the carrier today, 489 from memory...  :cheers:
